  • Posted by Pat Bray on September 16, 2011 at 11:14 am
    Hi, I was wondering, if I wanted to create a clam snapping randomly using a wiggle on the rotation for the front shell, and then use ‘thisComp.layer(“Clam Front”).transform.rotation on the back to match, is there a way of inverting the movement because at the moment the back is copying the front rather than moving the opposite way and opening the shell…. hope this makes sense!
    David Maxwell replied 14 years, 11 months ago 3 Members · 2 Replies
  • Dan Ebberts
    September 16, 2011 at 8:32 pm
    Just add a minus sign in front of the expression, like this:
    -thisComp.layer(“Clam Front”).transform.rotation
    Dan
  • David Maxwell
    September 29, 2011 at 12:16 am
    this may be a bad way to shortcut it but I just created a new solid that was the same size and color as my comp and applied the transition to that.
