Activity Forums Panasonic Cameras circular polarizer filter
  • circular polarizer filter
    Posted by Arthur Luhn on May 13, 2007 at 4:21 pm
    Hello,
    Is it possible to mount a 82 circular polarizer on the lens of the hvx200 and then put the lens housing (the box) back on?
    My thinking is that even if it is, how do i manipulate the lens to filter out reflection- reach within the housing?
    I do have a extended matte box from cavision.. is it better to buy a 4 x 4 polarizer filter?
    Suggestions appreciated..
    Rennie Klymyk replied 19 years, 4 months ago 4 Members · 4 Replies
  • Christopher Pavsek
    May 13, 2007 at 10:24 pm
    Yes you can put it on, but. You take the lens shade off, put the filter on, adjust the filter to your needs, then if you must, put the shade back on. You can’t reach the filter with the shade on unless you want to sping the filter with your finger on the glass, of course and you don’t mind a big fat fingerprint.
  • Rennie Klymyk
    May 14, 2007 at 4:59 pm
    [Original Idiot] “Is it possible to mount a 82 circular polarizer on the lens of the hvx200 and then put the lens housing (the box) back on?”
    Use a gobo or french flag to block light off the lens for the shot.[Original Idiot]
    “. is it better to buy a 4 x 4 polarizer filter?”
    4×4 filters are linear polarizers which are stronger but they can reach black out effect. Your matte box must have a rotating filter drawer.
    Circular polarizers have a second element that is a light baffle that re-scatters the light after polarization. This allows beam splitters used for exposure metering and auto focus to function properly. Most importantly is metering. The polarizing effect will change as you move the camera off axis from your light source.
    “everything is broken”
  • David Smith
    May 17, 2007 at 12:49 am
    [Rennie] “4×4 filters are linear polarizers which are stronger but they can reach black out effect.”
    Actually, either linear or circular polarizing filters are available in 4×4, or any other size. For example:
    https://www.photofilter.com/tiffen_4x4_polarizer_filters.htm
  • Rennie Klymyk
    May 17, 2007 at 5:30 pm
    Thanks David, I guess I’ve always used circular polarizers that thread right on the lens and square linear filters on my lights. They’re always marked for polarity and have to point a particular direction.
