Circular Path Data Stays the Same?
hi!
I have a series of circles in a design that have smaller circles that orbit around their respective parent circular paths.
To get the smaller circles to orbit around the larger path I have copied the larger circle’s path data and pasted it to the position of the smaller circles. With some manipulation of the keyframes, it works nicely!
Now when I copy another circle’s path data and then paste it to another dot, the first, larger path is the path that the circle is assigned to. – Not the new smaller circle path, I just copied.
I restarted the program a few times. I purged my memory, not my disk cache, and am still experiencing the same issue.
Is there a way to clear clipboard path data? Any other suggestions or ideas?
Thank you kindly in advance.
