Activity › Forums › Apple Final Cut Pro › circuit math
circuit math
Posted by Craig Alan on August 5, 2015 at 6:32 pmImac I7
pegasus R4: input 100-240 vac, 50-60hz, 5A.
mercury elite pro dual power supply: AC INPUT 100-240v-2.0A
DC OUTPUT 12V-6A
surge protector: max 15 amps.
house circuit breakers say 20.
what’s the math?
how many raids can i daisy chain without overloading the surge protector of house circuit?Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Claude Lyneis replied 11 years, 1 month ago 5 Members · 8 Replies -
Noah Kadner
August 5, 2015 at 6:45 pmThose draws are typically max- I’m guessing you’ll be fine up to 10. Though at that point a NAS or SAN would be far more efficient both in terms of electricity and performance.
Noah
FCPWORKS – FCPX Workflow
Call Box Training -
Craig Alan
August 5, 2015 at 6:57 pmSo I could easily plug in my iMac and up to 10 daisy chained raids? I need 4 pegasus raids and 2 mercury raids. into one outlet/surge protector. If its safe. of course the room circuit would include the lighting and every thing else in the room if its all on one circuit. the panel is not labeled.
but if its covered by the surge protector’s 15 amp max that would make me feel safe about that aspect of it.
Craig Alan
August 5, 2015 at 7:12 pmSo I could easily plug in my iMac and up to 10 daisy chained raids? I need 4 pegasus raids and 2 mercury raids. into one outlet/surge protector. If its safe. of course the room circuit would include the lighting and every thing else in the room if its all on one circuit. the panel is not labeled.
but if its covered by the surge protector’s 15 amp max that would make me feel safe about it
What had me confused was the
5A:
But i gather that is not power consumption? According to an article i just found the power consumption on an R4 is 52watts.
And a 20amp circuit can provide 2400 watts according to another article.Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Jeremy Garchow
August 5, 2015 at 7:37 pmWatts = Amps * Volts
therefore
Amps = Watts/Volts
If the draw of one raid is 52W. Then 10 raids would be 520W.
If we assume a much lower voltage than what it typically available in US power of 100V
520W/100 Volts = 5.2A
A draw of 5.2 Amps is plenty for both the 15A surge and 20A circuit. And since the average voltage is somewhere near 115 or 117V, your amperage level will go down, which is good.
Jeremy
John Fishback
August 6, 2015 at 7:11 pmI suggest you call Pegasus and get the story from them. If 52 w is correct then 5a from the Pegasus spec makes no sense (could it be .5a?). You’re covered by the circuit breaker which will trip if you exceed 20a. However, if the drives pull close to 5a at times, you’ll be limited to 2 or 3 RAIDs plus your other gear. Find the real draw of the Pegasus.
Craig Alan
August 7, 2015 at 12:30 amThat was my concern when I posted.however the 52watts is from the chart they referred me to when I called them.
and the label from the raid
So I gather that the input is not the same as power consumption
Jeremy Garchow
August 7, 2015 at 1:18 amInput is the max load and frequency of power the power supply can handle (so that power supply can handle an incoming power source of anywhere from 100-240v @5A max.
It has nothing to do with how much the raid will draw.
Claude Lyneis
August 7, 2015 at 4:01 amI agree. The 52 W is probably an average power and relates to an average current. When they are first turned or or maybe actively seeking date, the surge current could be much higher. That is what will trip your breaker. So there may not be a simple answer.
