Activity › Forums › Avid Media Composer › Circle Wipe – Can i make it look like looney tunes?
  • Circle Wipe – Can i make it look like looney tunes?
    Posted by Fnichols11 on November 30, 2006 at 7:09 pm
    I am a somewhat new user of AVID and I’m using it at a school computer lab (not my class just helping a friend) it’s the Mac version. I want to use the circle wipe but I can’t get it to actually animate. I’m using it on the last clip so I can create the looney tunes effect where it closes in on someone’s face, stops, and continues to close all the way. Can anyone help me with the steps to create this? I’m thinking it should be pretty easy but my lab time is limited so I don’t have access to alot of experimentation and researching the help files. Thanks!!!
    Frank
    Oakmozart replied 19 years, 10 months ago 2 Members · 1 Reply
  • Oakmozart
    December 1, 2006 at 5:50 pm
    Apply the Circle Wipe Effect, and keep in mind that you will have to experiment somewhat to figure out just how many frames you need total for the effect. Create keyframes (enter Effect Mode and click the “Add Keyframe” button underneath the right-side, aka “record” side of the Composer monitor) in the middle of the effect to hold the wipe on your subject’s face. Adjust the keyframes as necessary using the controls in the Effect Editor. I don’t know if it will let you adjust the position of the circle wipe (I’ve never tried it and I’m not in front of my Avid), so there’s a chance the wipe will only be in the exact center of the screen. If that’s the case, and your subject doesn’t fall within that area, you might not be able to use this effect to achieve what it is you’re hoping for…
    …however, if you’re on Avid XPro or above, go into the Effect Palette, click on the “Illusion FX” category, and select the Iris effect…which will give you EXACTLY what you want. Keyframe it the same way as above, and if I remember correctly, it will allow you to place the position of the circle you want, allowing you to keyframe it exactly where you want it and for the duration you want it.
    Consult the manual on creating/editing effects if you need more help. You can access the online version from the Help Menu at the top-left of your screen.
    Hope that helps!
