Activity Forums Adobe After Effects Circle mask-perfect circle eludes me
  • Circle mask-perfect circle eludes me
    Posted by Randal Radabaugh on September 8, 2010 at 1:05 am
    It seems I need assist again..
    Hello, am trying to create a perfect circle mask in center of
    comp. Now everything I have read and seen says…..
    Using elliptical mask tool, use shift, but this does not work for need.
    Also, select layer,DBL Click elliptical mask tool and it should create what I need. but it only creates an elliptical mask.
    This mask will have an expression that rotates it, with concentric more circular masks within to create rotating circles within.
    Every time I think I get a circle and add expression, it is all over the place. wiggle(.4,180)
    what Am I missing? why does it not make a perfect center in comp?
    Todd Kopriva replied 15 years, 12 months ago 2 Members · 3 Replies
  • Todd Kopriva
    September 8, 2010 at 3:52 am
    Here’s one way.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Randal Radabaugh
    September 8, 2010 at 6:03 am
    EDIT: I figured it out, lol, my comp size was wide…
    need to adjust comp size to a square…. LOL..
    err actually the layer..
  • Todd Kopriva
    September 8, 2010 at 6:14 am
    So, you edited to say “LOL” a couple of times, but you didn’t bother to change the part where you said that we were lying?
