Activity Forums AJA Video Systems Cinewave – Kona conversion
  • Cinewave – Kona conversion
    Posted by Tom Mooney on November 18, 2005 at 9:21 pm
    We just put our Cinewave edit suite to bed. I need to transfer certain projects over to the Kona editing suite. Question about the footage. Will the Cinewave footage playback on the timeline or is it best to go back and re-digitze, or just render the footage. Any other things we should look for?
    Thanks in advance.
    Ben Cheng replied 20 years, 10 months ago 3 Members · 2 Replies
  • Scott Shucher
    November 19, 2005 at 4:30 am
    Tom, I made the conversion over the summer from CineWave to Kona 2.
    I did have to resurrect several CineWave captured projects thru the Kona 2. Although the AJAYUV codec is supposed to be CineWave friendly, I had inconsistent results. I most cases I just re-rendered the timeline to the Apple 10 bit codec with excellent results.
    In one case, where the Kona 2 timeline had a multi-layered video effect, I got some video artifacts using the 10 bit codec after rendering. I re-set the video processing tab (Sequence settings) to an 8 bit render rather than 10 bit. (Remember, CineWave was an 8 bit codec, which is how my original footage had been captured) and this took, care of the artifacting.
    All in all it was a pretty easy transition. Uninstalled the Cinewave software and card, install the Kona 2 card and software and away I went.
    Good Luck.
  • Ben Cheng
    November 22, 2005 at 12:37 pm
    Hi guys
    Did an upgrade from FCP 4.5 to 5 + CineWave to Kona LS
    Experienced an increase in contrast, when rendering using AJA Kona 2Vuy codec for the sequence
    This affect any kind of render, either transition or filter
    System Info :
    PM G4 Dual 1.42Ghz
    1.5GB RAM
    Kona LS + KL Box
    ATTO UL3D
    OS X 10.3.9
    QT 7.0.3
    FCP 5.0.3
    AJA Kona LS 1.1.4
    ATTO 3.2.0 (for OS X 10.3.9)
    May I know if there’s a workaround to this ?
    Cheers
    Ben Cheng
    The Media Village
