Activity Forums Maxon Cinema 4D Cineware Delay Effector Issue
  • Cineware Delay Effector Issue
    Posted by Ivan Lüthi on February 11, 2016 at 12:19 pm
    Hi there,
    Its driving me crazy, I’ve put a Polygon Object into a Fracture Object, then I keyframed the Polygon object (position), and I’ve added a Delay Effector to the Fracture Object. Up to this point everything works fine, there is some bouncy movement on the object. Finally I’ve added a Mograph Tag to the Fracture Object, clicked on “Bake” and a External Compositing Tag to the Polygon Object inside the Fracture Object for later use in Cineware AE and this is the point where something’s going wrong.
    When I extract the Cinema scene in After effects, the Null from the External Compositing Tag is not bouncing, it’s static.
    What am I doing wrong?
    I’m using Cinema R16 & After Effects CC 2015
    Thanks for helping me out!
    Andy Sills replied 10 years, 6 months ago 2 Members · 1 Reply
  • Andy Sills
    February 12, 2016 at 3:03 pm
    That sounds strange, if you’re baking the objects movement then that should work perfectly.
    Did you try emptying the cache from AE? (Edit>Purge>All Memory)
    What are you wanting to do with the object? Are you animating something within AE on the object? Or do you just want that object in the scene?
