Activity › Forums › Adobe After Effects › Cineware – change project to 24fps?
  • Cineware – change project to 24fps?
    Posted by Greg Neumayer on December 21, 2013 at 12:04 am
    I’ve switched a 30fps project to 24 in C4D, both in the proj. settings as well as the Render settings. When I import it to AE, AE only will see it as a 30fps source. Ok, so just manually change the interpolation to 24, right? But when I do that, it doesn’t change the length of the C4D source. It simply ends when AE gets to the end of it’s original length, effectively clipping the last part of the C4D file.
    My workaround for now is to just leave C4D as 30fps, let AE bring it in at 30fps, and precomp the C4D layer in it’s own 30fps precomp (in my 24fps main comp).
    Anyone else having this issue?
    (C4D r14 Broadcast)
    Antifreeze Design
    https://www.antifreezedesign.com
    Roland R. kahlenberg replied 12 years, 9 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    December 21, 2013 at 12:25 pm
    I’m not seeing your issue on my end. The Render Settings should overwrite all other fps settings in C4D. Are you certain that you’ve gone to the menu item, Render>Edit Render Settings?
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
