Activity Forums Adobe After Effects Cineware: Application Error when rendering from After effects
  • Cineware: Application Error when rendering from After effects
    Posted by Ceri Allen on February 20, 2021 at 1:49 am
    I am working in after effects and have some 3D models used within the composition from cinema 4d files. When I set the after effects compositions to render they fail with the error ‘Cineware Application Error’ (screen shot of full error message attached). I have tried setting the 3D renderer in the composition settings to cinema 4D instead of classic 3D which at first seemed to work when I tested it, but has also just failed with the same message. Does anyone know how to fix this?
    Brendon Murphy replied 5 years, 6 months ago 2 Members · 3 Replies
  • Brendon Murphy
    February 23, 2021 at 2:06 am
    Was there any helpful info in the bug report? Maybe an error code?
  • Ceri Allen
    February 23, 2021 at 11:26 am
    I tried to find the bugreport by following the directory path in the error notice but I cannot find it. Have tried spotlight search for Maxon Cinema 4D R22 folder, it locates the one in the applications folder but no bugreports in this. Also have tried spotlight searching bugreport.txt but no files come up for this!
  • Brendon Murphy
    February 23, 2021 at 12:17 pm
    Perhaps it’s a hidden file? You could try enabling hidden files like this: https://www.pcmag.com/how-to/how-to-access-your-macs-hidden-files
