Activity › Forums › Apple Final Cut Pro Legacy › Cinetools Pull list and EDLs Question..
  • Cinetools Pull list and EDLs Question..
    Posted by Seawild on November 20, 2006 at 7:55 pm
    Hello Guys,
    I am wondering if CineTools can export a list that has both Keycode and Source Timecode information… I have heard different things on this..
    We are scanning and conforming a 16mm Sundance Film that was edited on FCP 5.
    Dailies were done to DVcam with 24/29TC and keycode burn in.
    Thanks so much, Chris
    Seawild replied 19 years, 10 months ago 1 Member · 3 Replies
  • Seawild
    November 21, 2006 at 5:58 am
    Did some searching.
    I think that if; an ale log and a FLX file was imported into Cinetools 3 and then imported into FCP 5.1 successfully and the editing was done using these clips from the ALE & FLX files, created from the telecine… there should be no problem exporting a EDL with key and source TC back to Cinetools 3 and creating 23.98 EDLs with source TC and KC, (maybe bins?). I’ll want to create an MS Excel tab file? as well as something we can import into Filemaker?, Looks like Cinema Tools 3 can also create a negative cut list as well.
    got link?.
    chris
  • Seawild
    November 21, 2006 at 6:20 am
    oohhh…. doop!
    from apple.com
    Film Support:
    Cinema Tools 3 included
    Support for 35mm 3-perf, 35mm 4-perf, and 16mm-20
    Comprehensive, integrated film management tools
    View Feet and Frames in Timeline
    View keycode and ink number overlays on video in Final Cut Pro
    Film data information in Final Cut Pro Browser
    24-fps EDL I/O
    24-fps EDL conversion to and from 29.97 fps
    Import ALE, ATN, FLX, and FTL files in both Cinema Tools and Final Cut Pro
    Track key numbers, ink numbers, video and audio timecode
    Output the following lists:
    Cut list
    Change list
    Optical list
    Pull list
    Dupe list
    Missing elements list
    Audio EDL
    Link media to database
    Synchronize database with Final Cut Pro
    View film data directly in Final Cut Pro
    Search and sort
    Poster frame capability
    Conform clips to specified frame rate
    Reverse telecine function in either Cinema Tools or Final Cut Pro
    Export ALE files
    Import and export Final Cut Pro batch lists
  • Seawild
    November 22, 2006 at 1:46 am
    I think I understand the problem a little better..
    This is roughly what I need from an EDL-
    Foot/ Duration/First-Last Key/ Start TC/ Tape#/LRoll/CRoll/Clip Name
    1677 163 EH 56 7015-6141+02 05:36:34:10 VT001 AIR74 C132 50A(c)
    This is what FCP kicks out –
    Shot Time Duration Keycode In Frame Out Frame Roll Clip name
    002 02:00:08:00 00:13:25 EB 73 6343 9660&14 9677&05 A66 25C-4PU
    So it would seem take FCP can NOT create an EDL that has both Keys and Tape #….
    So my question is now how do I merge the two EDLs into one? Or can this actually be done now with Cinetools 3?
    Also can FCP output “Duration” as frames only?
    Thanks, Chris
