Activity › Forums › DaVinci Resolve › Cinemascope output
  • Cinemascope output
    Posted by Bojan Mastilovic on September 22, 2011 at 3:29 pm
    Hello there, I am working on a movie, shot on a 35mm, cinemascope 1:2,35.
    The scanned images are in 1828×1556 resolution, with 1:2 pixel ratio.
    It roughly is 1:2:35… Resolve sees it properly, and the preview looks fine.
    But,
    We have to output it to DCP compliant scope image: 2048×858, square aspect ratio (1:1) any thoughts how can we accomplish it through Resolve? We had no luck using formats window.
    Thanks for the answers,
    Bojan
    Gustavo Bermudas replied 14 years, 12 months ago 3 Members · 5 Replies
  • Robert Houllahan
    September 23, 2011 at 4:01 am
    Can the DCI creation package do the reframe? Otherwise maybe After Effects or Shake, etc? That frame is the standard 2K squeezed scope size have you asked the people doing the compression if the DCI compressor does that?
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
    http://www.cinelab.com
    MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
  • Gustavo Bermudas
    September 23, 2011 at 8:15 am
    Can you render it as square pixel and resize acordingly?
  • Bojan Mastilovic
    September 23, 2011 at 9:44 am
    No, we are the ones that will do the encoding, and our system – Doremi Rapid, does not have any settings for resizing and reframing.
    It needs the exact size as specified by DCI specs…
    regards,
    Bojan
  • Bojan Mastilovic
    September 23, 2011 at 9:46 am
    The question was, can the resizing be done in resolve?
    We can do it in any compositing application, but we would like to skip one render phase – as we are talking about full feature length.
    regards,
    Bojan
  • Gustavo Bermudas
    September 23, 2011 at 6:22 pm
    I’ve rendered out doing the resizing for DCP from Resolve successfully, however, my source was 1920 X 1080 2.40, in your case since it’s scope, I would try the four different scaling options you have in the Format – Output tab and render it square pixel.
    I’m sure at some point I’m going to have to do this too.
