Activity › Forums › Adobe After Effects › Cinema4D: Using Compositing tag’s with Clone’s.
  • Cinema4D: Using Compositing tag’s with Clone’s.
    Posted by Dante Miles on April 8, 2013 at 8:01 am
    I have a project where several circle-shaped screen’s pop out, I want to place a picture on one of them in After Effects, however all of them are clone’s. How do get this to work?
    Darby Edelen replied 13 years, 5 months ago 3 Members · 2 Replies
  • John Cuevas
    April 8, 2013 at 2:40 pm
    You might want to post this in the https://forums.creativecow.net/cinema4d forum.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Darby Edelen
    April 8, 2013 at 2:42 pm
    You should be able to use an External Compositing tag on the Cloner object so long as the ‘Cache’ option is enabled.
    This is probably a better question for the Cinema 4D forum.
    Darby Edelen
