Activity Forums Maxon Cinema 4D Cinema4D Redshift textures lost in “ramdisk ”
  • Cinema4D Redshift textures lost in “ramdisk ”
    Posted by Chad Ridgeway on August 18, 2024 at 10:15 am
    Thousands of textures across hundreds of folders trying to get loaded in from ram. Even the file names are different making re-linking impossible
    Kouraib Abdmalek
    replied 2 years ago
    2 Members · 1 Reply
  • Kouraib Abdmalek
    August 18, 2024 at 2:12 pm
    Hi Chad,
    You can use the relink feature in RS if it doesn’t work for you then I think the problem is related to the software, you may need to reinstall the program to solve the problem you could use another computer before that to make sure the problem is with the program on your side.
    I hope this will help you.
