Activity Forums Maxon Cinema 4D Cinema4D hair symmetry problem
  • Cinema4D hair symmetry problem
    Posted by Monika Zidaell on February 15, 2012 at 1:33 pm
    Hello,
    I want to add hair to an object , i made a mouse character and added whiskers. I used the symmetry tool in the guides section to do so. However when i press “Make Editable”, i can see it as the guides but the hair on the other side of the object is gone. What to do to make it work?
    Monika Zidaell replied 14 years, 7 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    February 15, 2012 at 4:45 pm
    What are you making editable?
  • Monika Zidaell
    February 16, 2012 at 7:17 am
    The guides, under the hair settings. When you turn on symmetry it shows the hair on both sides of an object. There is a function to make the guides editable and root it to the object. However , although im able to see the guides on both sides of the object it shows me the hair only on one side of it.
