Cinema Tools/Final Cut – Able to change clip name after batch capture?
I`ve been refreshing myself on Cinema Tools (did a super 16 short or two, a few years back as assistant editor, but mostly have done digital jobs since then).
I have gotten up to speed on the majority of the workflow again, from the manual, but I wanted to double check something.
Am I able to change the names of my clips in Final Cut 7 AFTER I have batch captured my telecined footage from tape and still maintain the relationship to the master clips in Cinema Tools for creating film lists for conform?
Last I remembered, only the source clip that Final Cut references on the drive needs to remain the same as the CT database, but I wanted to double check. I don`t have access to any of my old footage to test at the moment.
Thanks.
