Activity › Forums › Apple Final Cut Pro Legacy › Cinema Tools?
Cinema Tools?
Posted by Hyperion on May 23, 2005 at 2:40 pmHi
I’m wondering how to work with cinema tools. What is it, is it included with final cut pro? I
Hyperion replied 21 years, 4 months ago 3 Members · 6 Replies -
John Pale
May 23, 2005 at 3:09 pm[16:9] “Could i produce 24p from 60i video with cinema tools?
“No. Cinema Tools is primarily for film work…its main function is to maintain a database of Keycode numbers for a film conform of an FCP edit. It also can be used to batch remove pulldown from film to tape transfers for 24fps editing. It does not convert anything to 24p
Graeme Nattress does make a great filmlook plug in which might do the trick for you. There is a demo version available.
Hyperion
May 23, 2005 at 4:08 pmThanks John
Any tutorials-guides about how to get 24p inside final cut pro HD? I know how to do it in After effects but I don
Graeme Nattress
May 23, 2005 at 5:11 pmhttps://www.nattress.com/standardsConversionMovie.htm
Shows you how it can be done inside FCP.
Graeme
– http://www.nattress.com – Film Effects for FCP
Hyperion
May 23, 2005 at 6:06 pmThanks Graeme
but I had in mind something that can be done with native FCP tools, like interpeting fields and then blending them. I mean I want to do the same thing I do in after effects but in FCP. like this tutorial:
https://www.gl1universe.com/articles/filmlook/broadway1.php but without using AE. since I -
Graeme Nattress
May 23, 2005 at 6:15 pmKen Stone has just such a tutorial on his site, although I don’t recommend such tricks for producing a film look as they never look as good as a plugin (and yes, I do sell such plugins, but trust me, I wouldn’t have written them and wouldn’t be selling them if I could have achieved the same quality of effect without using them). The above trick basically is a blend de-interlace. If you want that effect, there’s plenty of free and no-so-free plugins that will do it in FCP. However, it does 30p not the 24p you need for the true film look, and it won’t allow you to edit the video on a 23.98fps timeline which is what I thought was needed.
Graeme
