Activity › Forums › Apple Final Cut Pro Legacy › Cinema Tools Question
  • Cinema Tools Question
    Posted by Eli Mavros on May 11, 2009 at 7:02 pm
    Hey Cows,
    I have some telecined footage that was captured and I already broke up into subclips. I’ve decided that it would be best if I work at 23.98 and remove the pulldown. Is there any easy way to do this so that my subclips connect to the new reversed telecined clip? Or do I have to start from scratch?
    Eli
    Arnie Schlissel replied 17 years, 4 months ago 3 Members · 3 Replies
  • Shane Ross
    May 11, 2009 at 7:30 pm
    Gonna have to start from scratch. The supclips reference a different frame rate, so they won’t connect at all.
    Shane
  • Eli Mavros
    May 11, 2009 at 7:33 pm
    Thanks Shane,
    Thought so. Bummersville. I see that the subclips are marked as master clips, and I can batch reconnect them to the source media file…but I am a bit weary of doing it do to the TC change.
    Eli Mavros
  • Arnie Schlissel
    May 12, 2009 at 2:18 am
    [Eli Mavros] “I have some telecined footage”
    Stop right there. If you have telecined footage, you probably have ALE or FLX files to go with them. You should import those logs into Cinema Tools, use that to generate an FCP batch list & then you can capture & remove pulldown. This will save you a lot of pain & suffering (& probably some $$$) later on.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
