Activity Forums Apple Final Cut Pro Cinema Tools Luminance Shift
  • Cinema Tools Luminance Shift
    Posted by Dale Robinson on February 9, 2013 at 10:05 pm
    When conforming 60p to 24p in Cinema Tools is it typical to get a slight luminance shift ?
    I made a copy of a 60p clip, conformed the copy and then matched into the original
    and the luminance dropped on the conformed clip.
    Dale Robinson replied 13 years, 7 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    February 10, 2013 at 12:12 am
    Are you seeing this after importing or just in QT?
    If you are simply conforming frame rate in CT, there’s no change to the file except it gets a 23.976 frame rate.
    New media is not created.
  • Dale Robinson
    February 12, 2013 at 12:04 am
    Thanks Jeremy, Not sure why I got the luma shift but I tried it again and it worked fine.
