Activity Forums Apple Final Cut Pro Legacy Cinema Tools logs
  • Cinema Tools logs
    Posted by Neil001 on February 22, 2007 at 11:59 pm
    I’m about to start a made for TV movie shot on a Sony HD-900 camera. They will be transfering the camera tapes to digibeta SD for editing. The online willl be done from the camera original tapes. I was sent a test FLX and ALE files from the telecine facility who are going to be syncing the double system audio. The files contain 23.98 hd source code, sd record code, and dat audio code. I was able to import the FLX and ALE files into CINEMA TOOLS (for use with Final Cut Pro) however I could not read the HD source code. Unless I’m missing something CINEMA TOOLS only allows for 2 timecode logs and 1 key code number log. But not a third TC log. Is this correct? Any suggestions?
    Neil001 replied 19 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
