Activity Forums Apple Final Cut Pro Legacy Cinema Tools help
  • Cinema Tools help
    Posted by Katherine on April 19, 2005 at 4:25 pm
    I need to edit in 25 fps Pal video, then generate a 24 fps EDL so it can be conformed to film. I know that Cinema Tools can do this, but how should I go about setting this up, what do I have to do before/after I capture the media. Is there a set of instructions somewhere that can talk me through this??
    Will Macneil replied 21 years, 4 months ago 3 Members · 2 Replies
  • Misha Aranyshev
    April 19, 2005 at 6:33 pm
    24@25 was given special attention in FCP 4.5 update thanks to the petition Will MacNeil started. There is Editing Film With Final Cut Pro
    in a PAL Environment
    section in New Features under help menu.
    Are you sure you need 24 fps EDL? Film is the same number of frames per foot no matter what fps.
  • Will Macneil
    April 20, 2005 at 12:17 pm
    I’d hazard a guess that you’d actually like a 25fps edl even though you’re editing at 24fps. This is what most neg cutters want as far as I know. You’ll only need Cinema Tools if you need to create film cutlists or audio edl’s refering to sound roll and timecode from a flex file (or any telecine log.)
    Either way, do yourself a favour and start off with the 24@25 easy setup and if you’re working from something other than DV, modify it to support your I/O hardware. This will tick all the right boxes for sequence timecode rates and so on.
    I’m here if you have specific questions,
    Will
