Activity Forums Apple Final Cut Pro Legacy Cinema Tools Conform
  • Cinema Tools Conform
    Posted by Rick Mcnealy on August 10, 2005 at 6:10 pm
    I have taken a clip (1280×720 59.94 Varicam captured FW) into Cinema Tools to conform from 60fps to 23.98 to get the clip slo-mo…That works fine.
    When I take that file and import into AE I end up with a halfsize image. 640×360…what am I missing?
    Rick Mcnealy replied 21 years, 1 month ago 2 Members · 2 Replies
  • Jerry Hofmann
    August 11, 2005 at 1:50 pm
    Sounds like you changed the size of the file in CT… note that it’s exactly half the size of the original…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Rick Mcnealy
    August 11, 2005 at 6:42 pm
    CT hase no size dialog box. ALSO the file is 1280×720 in the finder yet opens to half size movie (player window size) by default. When you go to QT’s actual size play mode it shows as 1280×720. When that is imported into AE for some reason there is something confusing it to think that it is half size. What am I missing?
