Activity Forums Apple Final Cut Pro Legacy Cinema Tools conform BEFORE or AFTER ProRes Conversion?
  • Cinema Tools conform BEFORE or AFTER ProRes Conversion?
    Posted by Daniel Clark on June 28, 2012 at 4:51 pm
    I shot a music video yesterday with a Canon 7D at 60fps with the intention of converting it all to slow motion (23.976) using the conform tool in Cinema Tools.
    My question is whether it’s better to conform the frame rate BEFORE or AFTER converting the footage to ProRes LT (so converting the H.264 from the 7D) or whether it makes any bit of difference.
    Alan Okey replied 14 years, 2 months ago 4 Members · 4 Replies
  • Shane Ross
    June 28, 2012 at 5:20 pm
    After. Duplicate the clip if you want to use it normal speed too. this conform is destructive…no going back. Unless you convert the master clip again.
    Shane
    Little Frog Post
  • Alan Okey
    June 28, 2012 at 10:54 pm
    You don’t have a choice. Cinema Tools can’t conform long-GOP/interframe codec footage (h.264, XDCAM, HDV, etc.), only intraframe codec footage (Pro Res, DVCPRO HD, etc.).
  • Rafael Amador
    June 29, 2012 at 12:04 pm
    [Alan Okey] “You don’t have a choice. Cinema Tools can’t conform long-GOP/interframe codec footage (h.264, XDCAM, HDV, etc.), only intraframe codec footage (Pro Res, DVCPRO HD, etc.).”
    If I’m not wrong the H264 from the Canon is Intra (1f GOP) so can be directly conformed by CinemaTools.
    XDCAM MPEG-2 intra (Nano-Flash) can be conformed as well.
    rafael
    http://www.nagavideo.com
  • Alan Okey
    June 29, 2012 at 12:24 pm
    You’re correct. Add AVC Intra to the list as well. It’s interframe codecs that are not supported.
