Activity › Forums › Apple Final Cut Pro Legacy › Cinema tools and FCP workflow for film project
  • Cinema tools and FCP workflow for film project
    Posted by Mabelv on January 6, 2006 at 2:41 am
    Hello:
    I am logging and capturing my Super 16mm short film
    that has been telecine (MOS audio) to an HD
    server at a local telecine house. I want to have the option of
    going back to
    film, however, a final HD master will be the final
    product that will be done at the facility.
    The telecine facility gave me DVCAM dubs at
    29.97-
    letterboxed. They don’t use flx files tough and was
    told that I have to manually enter this information in
    CT.
    What would be the workflow for this project without
    flx files? Is it ok not to have flx files if I ever
    want to go back to
    film?
    -Would I capture at 29.97 DV capture present first?
    ***The producer at the facility mentioned to capture
    clips according to camera rolls. There are 3 camera
    rolls total,( 2 tapes) each approximately 25-30.
    Whenever I try to capture these 3 clips I received a
    drop frame warning, then I notice that the TC in the
    window burns are different y 2 seconds in the viewer
    window.
    – How and when in the workflow do you manually enter
    the In point using the punch on the film? Is this done
    after
    digitizing? I thought that I would have to create a
    CT database and
    “manually” enter the information there. Is this
    correct?
    – Also, after successfully capture in FCP should I
    create a
    new database in CT and import clean clips and have the
    pulldown removal there?
    Should it be at 24 fps or 23.98 fps?
    At what point in the process do I sync the sound files
    to the MOS film? Do I need to re-import these clips to
    CT and replace the older non sunc clips. The sound was
    recorded at 30 fps while film was at 24fps. Do I just
    need to speed up the sound by 0.1% or make it at 99%
    speed?
    -How do I make sure I mantain a clean environment for
    a final conform in HD?
    – I assume that after all these is done I will create
    a sequence at 23.98 and edit then.
    In your experience, is there anything else that I
    need to consider while setting the FCP project,
    sequence and timeline? The goal is to edit in FCP and
    then go
    back to the telecine facility with the sequence and
    conform to HD
    and have the film color correction then. The final
    master will be in HD.
    Thanks in advance for your advice,
    Mabel Valdiviezo
    haikufimsorg@yahoo.com
    https://www.soledadisgoneforever.com
    Mabelv replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
