Activity › Forums › Panasonic Cameras › cinema tools and 1080i 60 24pa to 23.98 rev telecine
Posted by Zacklg on May 3, 2006 at 1:02 amis cinema tools a proper way to change(rev-telecine) 1080i 60 24pa from the hvx-200 to a 23.98 frame rate to edit in 24 progressive for a film out of post?
zak and daryn
Mike Schrengohst replied 20 years, 4 months ago 4 Members · 4 Replies -
Mike Schrengohst
May 3, 2006 at 2:09 pmNoah, have you tried this?
I have a backlog of 1080 24pA footage that was shot with my HVX. I finally got my 5.1 in, does not remove the pulldown from 1080 24pA footage. I have tried every convolution. I set-up a 1080 23.98 sequence. Import from P2, click checkbox
to remove pulldown. I get a nice interlaced frame every forth frame.
You can import with the box not clicked, same thing. I tried importing with the box checked and unchecked with every different pulldown in set-up. It all looks the same.You can import the footage and then use Cinema Tools to remove the pull-down.
I also have Edius. I can import the same 1080 24pA file directly from the P2
and remove the pull-down and it looks great. So for now I use Edius to
process 1080 24pA footage shot with the HVX.Mike Schrengohst
http://www.MotionZoneHD.com -
Alex Viarnes
May 3, 2006 at 6:30 pmHi Mike, I’ve had the same experience with FCP 5.1..EVERYONE says just select the box on import but it does not work. What does work is select a clip in your timeline and then pull down tools and select “cinema tools reverse telecine”. This is really easy and works perfectly; apple really needs better documentation on this because I’ve checked around everywhere and no one has been able to tell me how to do it. I found it by sweat and tears.
Aloha
-A -
Mike Schrengohst
May 3, 2006 at 9:48 pm
