Activity Forums Apple Final Cut Pro Legacy Cinema Tools 30fps –> 24fps EDL conversion / EDL names
  • Cinema Tools 30fps –> 24fps EDL conversion / EDL names
    Posted by Sithcommander on May 20, 2005 at 9:17 pm
    Our offline edit is 29.97 fps offlineRT (low-res).
    Our online edit will be 24 fps 1080i24 HDCam (8-bit uncompressed) via Kona2.
    In order to convert the project, I use cinematools EDL conversion from 30fps to 24fps, then re-import into my online sequence.
    Reading up on onlining and EDL protocol, it’s been mentioned that REEL names should be short and alpha-numerics only, otherwise the EDL won’t allow proper re-capture.
    My reel names are uniformly: SCE-35001
    (three letters, a dash, and 5 numbers).
    Questions:
    1. Do I change Reel numbers and if so, how?…can I change the master clip Reel # and will that do it?
    2. What EDL format do I use? CMX 3600?
    3. Any other hints, advice, suggestions for using Cinematools and K2?
    Thanks in advance.
    Sithcommander replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
