Activity Forums Maxon Cinema 4D cinema to after effects
  • cinema to after effects
    Posted by Gon Perdigao on March 13, 2009 at 12:03 am
    Hi there i’m rendering a scene that i put the tag to external composition,and in the render settings i flag all in the composition project file.
    Cinema render all, but when i open the AE file nothing happens. The project don’t open, and after keeps the name as untitled project.
    In the folder that i saved the AE in cinema, they are two save projects with the same name, but neither one of them open.
    I export a lot from cinema to after effects, but now i have this problem.
    Can anyone help me?
    Thanks a lot
    Gon Perdigao replied 17 years, 6 months ago 2 Members · 2 Replies
  • Trevor Phillippi
    March 15, 2009 at 5:21 am
    Have you moved the AE plug from C4D ExchangePlugins director into your AE plugs directory? That will allow you to read and import the .aec file cinema will generate with your render. Let me know how you make out.
    Trevor
  • Gon Perdigao
    March 15, 2009 at 10:17 am
    yes i move, but the problem is not that, cayse a few hours earlier i render a project with external composition and i was working in after effects.
    I try a few times with different names and different file paths and the only thing that i could manage to work in AE was adding an external composition to the camera, and with that way i could export all the information to after effects.
    But i still don’t know what was the problem, i was working in a mchintosh.
    Thanks a lot for your reply
