Activity Forums Adobe After Effects Cinema to AE?
  • Cinema to AE?
    Posted by 459productions on September 18, 2007 at 6:43 am
    I hear about this alot lately. Being able to import a Cinema file into AE? My questions is exactly how do you do it? And it does not import a 3D object correct?
    KG
    Jeff Mcbride replied 19 years ago 2 Members · 1 Reply
  • Jeff Mcbride
    September 18, 2007 at 8:36 pm
    I’m by no means an expert with C4D but figured I’d answer. You’re correct that you cannot import a 3D object. You can import the cameras, lights, and nulls.
    You would need to create a C4D file, export it for AE, then import it, plus the rendered video file from C4D. Pop them all together and you can add elements from AE. As I said I’ve not done it super frequently so check this out, I think it tells you.
    https://www.studiodaily.com/studiomonthly/tutorials/howtutorials/6890.html
    Jeff McBride
    Motion Graphic Designer/Editor
    LimeGreen
    Chicago, IL
    http://www.limegreenproductions.com
