Activity › Forums › Apple Final Cut Pro Legacy › Cinema Display black line
  • Cinema Display black line
    Posted by Randolph Harrison on June 29, 2007 at 6:34 am
    Hey guys,
    My 23″ Cinema display has a hair sized horizontal black line running through the center of the screen. I have tried it on other computers with the same result. Any thoughts? Thank you,
    Randy
    G5 Quad 2.5
    20″ Cinema display
    23″ Cinema display
    6.5 gig ram
    FCP 5.1.2
    Rennie Klymyk replied 19 years, 2 months ago 2 Members · 1 Reply
  • Rennie Klymyk
    June 30, 2007 at 5:37 pm
    Contact tech support imediately if it’s still under warranty. The Apple warrantee is time rated so the older your monitor is the less it’s worth. If you read the fine print of the warantee they can replace and repair with used parts which is what happened to me. My 11 month old 23″ was replaced with 3 old used ones till I finally got one (with the same amount of dead pixels as my 1st) and that actually worked. I was without a monitor for over 3 weeks while all this was going on.
    “everything is broken”
