Activity › Forums › DVD Authoring › Cinema Craft NTSC encodes
  • Cinema Craft NTSC encodes
    Posted by Benn Gunn on February 7, 2007 at 10:37 am
    I’m using CCE to encode about 90% of my DVD content and have so far been pretty happy witht hte results. However, I’ve recently had a couple of NTSC projects which look awful. I’ve ended up having to re-do the encodes in Sonic Encoder, which has given me a usable result.
    My bitrates ranged between 4mbps and 5.2mbps on a multi pass VBR (between 5 and 10 passes – more passes on the lower the bitrate) with 9mbps as my maximum and 0.5mbps below my average as my minimum. I used the mpeg standard q-matrix preset, and all usual NTSC set up settings.
    Is there an issue with lower bitrate NTSC encodes thru CCE or is there something I can do to improve what I have?
    Eric Pautsch replied 19 years, 7 months ago 2 Members · 3 Replies
  • Eric Pautsch
    February 7, 2007 at 3:51 pm
    Hard to say without seeing your source. What is your source and how long is the video? I can say the max of 9 is way too high and .05 to way to low. Avoid going over 8 – lower if you can. Your allowing your encoder to go to .05 – that will give you results you won’t like at all.
  • Benn Gunn
    February 7, 2007 at 4:07 pm
    My minimum bitrate isnt 0.5. It’s 0.5 below the average (eg if average is 5 then minimum is 4.5). I havnt had any issue inthe apst with these settings in the past year.
    The source is a digi broadcast master, so its good clean footage that should encode well.
  • Eric Pautsch
    February 7, 2007 at 7:31 pm
    Sorry..misread your post. Which of thier products are you using? What don’t you like about the encode? Are there any scenes which might give encoders some problems (fast edits; quick flucuations in video levels, ect) Your settings sound good except the high setting. You can forced “I” frames in there top end encoders. If you have the space – consider a CBR encode as well.
