Activity Forums Maxon Cinema 4D Cinema 4d UV mapping Problem PLS ASAP
  • Cinema 4d UV mapping Problem PLS ASAP
    Posted by Josef Brockdorff on September 2, 2014 at 10:01 pm
    Hi Guys, so I’am trying to map this paper game using UV map, the thing is that when I map the first diamond ( an image showing a number) the mapping is also being done on the back of this same poly. I only want this to be on the front since I need a different number (map) on the back…Is there any way pls? This model below has 4 triangular flaps which opens and needs to be mapped on one side only. thanks in advance. Josef
    Adam Trachtenberg replied 12 years ago 3 Members · 5 Replies
  • Brian Jones
    September 2, 2014 at 10:52 pm
    each texture tag has an option called Side in the texture tag Tag tab. By default it is set to Both but it can be set to Front or Back which is what you will want.
  • Adam Trachtenberg
    September 3, 2014 at 12:01 am
    Did you say texture tag tag tab? 🙂
  • Brian Jones
    September 3, 2014 at 12:40 am
  • Josef Brockdorff
    September 3, 2014 at 8:36 am
    Hi, thanks but I tried that before and its coming messed up …take a look at these pls
  • Adam Trachtenberg
    September 3, 2014 at 3:21 pm
    Looks like you may have coplanar faces, i.e., two polygons in exactly the same position? When that happens the render engine has no way of knowing which one should be in front.
