Activity › Forums › Maxon Cinema 4D › Cinema 4D unable to move extruded geometry
  • Cinema 4D unable to move extruded geometry
    Posted by Mostafa Talebi on July 16, 2014 at 10:35 am
    That is very strange.
    I have imported a curve from AI and then extruded it in Cinema4D using extrude tool. Now, I cannot move the extruded geometry. What should I do?
    I have selected move tool. My selection mode is Object Mode ( I also have tried Model mode). Is there any problem?
    Thanks in advance
    Adam Trachtenberg replied 12 years, 2 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    July 16, 2014 at 12:40 pm
    First thing I would do is try copying the object and pasting it into a new scene. That will rule out whether or not your scene file is corrupt. If that doesn’t do it, check to make sure you haven’t done things that will prevent translation:
    * no protection tag on object;
    * axis locks aren’t enabled in the interface (x, y, z icons) or on the object (axis arrows show the correct colors);
    * the object isn’t on a locked layer;
    * there’s no tag or Xpresso preventing movement.
