Activity Forums Maxon Cinema 4D Cinema 4D tooo much light
  • Cinema 4D tooo much light
    Posted by Antonio Mars on February 15, 2016 at 12:42 am
    Hello, I’m new in cinema 4d, actually I’m just using it for my new animation about ship Titanic…
    I’ve download Titanic ship .3ds from internet and when I put it in Cinema the ship is overexposed and over illuminated.. Is there a way too remove light from cinema and see the ship the way he really is? It has colors but appears almost all white in cinema.. Here is the picture of how it looks in cinema, and how it really looks
    Adam Trachtenberg replied 10 years, 7 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    February 15, 2016 at 2:16 am
    Looks like the materials didn’t import as they were in the original file. You’ll have to go through them and adjust as needed.
    As for lighting, Cinema uses default lights which can be turned off in render settings if desired. Or if you add your own lights the default lights won’t be used.
  • Antonio Mars
    February 15, 2016 at 8:56 am
    So I need to increase saturation, make colors stronger? And is there some weaker light than default light that could look better?
  • Adam Trachtenberg
    February 15, 2016 at 4:24 pm
    I can’t tell what’s going on with the materials from the screen shot posted. They might have luminance which would negate any lighting.
    As far as the default lighting goes, you can adjust the position of the modeling lights but not the intensity. Best to create your own lighting by adding lights to the scene.
