Activity Forums Maxon Cinema 4D Cinema 4D to Preview Monitor?
  • Cinema 4D to Preview Monitor?
    Posted by Eli Coogan on April 26, 2012 at 5:49 pm
    I’m new to Cinema 4D, so excuse me if this seems elementary…
    Is there a way to preview work in Cinema 4D R13 (Prime) on a connected preview monitor (in my case: Flanders Scientific)? I was hoping to be able to do so before exporting the sequence and taking it into Final Cut Pro or After Effects.
    Thank you in advance!
    Eli Coogan replied 14 years, 4 months ago 2 Members · 2 Replies
  • Andrew Larson
    May 2, 2012 at 2:28 pm
    I would render out some still frames from parts of your animation that you are worried about being broadcast safe, then throw them into AE or FCP to preview on your monitor.
    Blur the lines between work and play.
    Andrew Larson
  • Eli Coogan
    May 2, 2012 at 6:17 pm
    Thank you for the response! That’s a pity that it can’t be done directly, but that method will do just fine. Thanks.
