Activity › Forums › Maxon Cinema 4D › cinema 4d to after effects
  • cinema 4d to after effects
    Posted by Susan503 on October 17, 2005 at 9:37 pm
    can anyone help me understand how to bring cinema 4d objects into after effects ( I am using C4D XL 6.0 and AE 5.5 on mac os 10.3.4). My desire is to create and light objects in C4D and animate them within AE. Is this possible? Do I need to create a movie in C4D or just an image? What format(s) are best, etc.
    Many thanks….
    Susan503 replied 20 years, 11 months ago 3 Members · 3 Replies
  • Chris Smith
    October 18, 2005 at 1:05 am
    AE will not accept objects. It only works with 2D flat planes, period. There are plug-ins that render what appears to be some 3D objects only because they sync up with the AE cam. One of those is Invigorator. It will accept some object formats but the control is extremely limited.
    The normal workflow is to do all 3D animation in C4D and render out your final render in multiple passes for control then composite those in AE. You can export your C4D cam data so that whatever you add to it in AE will sync up though.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Björn Marl
    October 18, 2005 at 7:04 am
    AE project export and Multipass Rendering is only supported since R7. I recommend getting a later release of CINEMA for this type of work.
    Cheers
    Bj
  • Susan503
    October 18, 2005 at 4:18 pm
    thanks for the help, guys. Much appreciated. Guess I have to bite the bullet and upgrade.
