Activity › Forums › Maxon Cinema 4D › Cinema 4d Title. Random Effector “in Order”?
  • Cinema 4d Title. Random Effector “in Order”?
    Posted by Ryab Smith on June 14, 2012 at 2:16 pm
    I’m trying to get text to rotate from a -90 degree angle to 0 degrees, and I am trying to make the first letter start the animation, move through the word rotating letter by letter, and have the last letter finish the move last. Is there a way to do this without having to do it manually?
    Adam Trachtenberg replied 14 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 14, 2012 at 3:08 pm
    Yes, it’s quite easy if you have mograph. Just create the text with the mograph text object, set the letter rotation to -90 in the letter>tranform tab, and then assign a plain effector (happens automatically if the text object is selected when you create the effector), set the parameters to rotation>H = 90, and then set the falloff to linear. Animate the effector to accomplish the rotation.
    Sample file: 4289_textrotation.c4d.zip
