Activity › Forums › Adobe After Effects › Cinema 4D Text Stroke Extrude
  • Cinema 4D Text Stroke Extrude
    Posted by Rob Bach on December 10, 2019 at 11:09 am
    The Cinema 4D renderer will not recognize the Text Stroke, if I want to extrude it as well. (Think “Toy Story” text)
    Has anyone found a technique to make this happen.
    Currently I need to Create Shape from Text. Then I can extrude the stroke on the shape.
    I then parent the shape to the text.
    This works, However, if I edit the original text.. I need to go through the whole procedure again in
    setting up the Shape from text outline.
    Would it be possible to apply an expression to the Shape layer to update?
    A lot of work otherwise.
    thanks in advance
    Rob Bach replied 6 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
