Activity Forums Maxon Cinema 4D Cinema 4d Spline Mask
  • Cinema 4d Spline Mask
    Posted by Jerry Aurello on November 16, 2020 at 2:38 pm
    Hi, Can someone please help me I’m having a hard time merging two object in spline mask . Whenever it’s enabled the object disappears but when I press the disabled button it appears. Anyone have a solution in this problem, Thanks
    Andy Kiernan replied 5 years, 10 months ago 2 Members · 1 Reply
  • Andy Kiernan
    November 16, 2020 at 4:34 pm
    I think the spline mask only works with closed splines, so perhaps it’s seeing the symmetry spline as not closed. Try collapsing the symmetry spline into a proper spline and see if that works. If you need to keep it in the symmetry object for some reason maybe stick a connect object in there for good measure. Not sure it will, but i hope this helps
