Activity › Forums › Maxon Cinema 4D › Cinema 4D render reverting back to old settings?
  • Cinema 4D render reverting back to old settings?
    Posted by Chris Bryant on October 13, 2010 at 11:00 pm
    I am working on a small project that involves candies falling from the sky. I’ve used one of Greyscalegorillas sets in his HDRI lighting kit. I am rendering a set of frames at a time, and the first 300 or so frames went fine.
    After reviewing these sets, I wanted to make some changes to my emitter, basically just increasing the output of the candies. When rendering in the picture viewer it renders what the old settings were, I have checked to make sure that the emitter wasn’t set on some different settings that I might have key=framed and it reverted back to those. I am completely lost on why it is doing this, I did attempt to use the mograph cache tag earlier and ended up deleting it later to make changes. Could this be the issue?
    Chris Bryant replied 15 years, 11 months ago 2 Members · 3 Replies
  • Chris Bryant
    October 13, 2010 at 11:55 pm
    Just a side note:
    Restarted both Cinema 4D and my computer.
    Created new camera, new emitter, and even new particles(candies).
    Saved as a different file and reopened in Cinema 4D.
    I do not have access to another computer with 4D on it, to see if the issue follows me there.
    Thanks again!
  • Adam Trachtenberg
    October 15, 2010 at 4:31 am
    You’re using a standard emitter? You realize that there are separate birth rate settings for the editor and renderer?
  • Chris Bryant
    October 16, 2010 at 2:30 am
    Yes, I am using a standard emitter. But I was unaware that there are different birthrate settings for the emitter and render. But I don’t know how these could have changed, it changed when I used a MoGraph Cache tag and then deleted it.
    I’ve looked and it’s probably as clear as day, but I cannot find the different birthrate emitter settings.
    C4d R11.5 64-bit Windows 7
