Activity Forums Maxon Cinema 4D Cinema 4D Render Error – Not enough memory…
  • Cinema 4D Render Error – Not enough memory…
    Posted by Thunder Waffe on August 18, 2012 at 12:06 am
    So I am trying to render the active view and I get an error:
    The file size is 541mb. I know it is large, but I need it done.
    I have 8gb of ram so I don’t see why I get this error.
    ThunderWaffe
    Gustavo Melo replied 13 years ago 3 Members · 6 Replies
  • Brian Jones
    August 18, 2012 at 12:27 am
    are you using a 64 bit version of Windows? If you are using a lot of clones are they set to be Render Instances?
  • Thunder Waffe
    August 18, 2012 at 3:04 am
    [Brian Jones] “are you using a 64 bit version of Windows? If you are using a lot of clones are they set to be Render Instances?”
    I am using a 64bit. And how would I set render instances?
  • Brian Jones
    August 18, 2012 at 3:10 am
    and using the 64 bit version of C4D (I forgot to ask)… To set Render Instances it’s in the Cloner’s Object tab, it makes the clones ‘instances’ instead of full copies and they hardly use any memory by comparison.
  • Thunder Waffe
    August 18, 2012 at 7:10 am
    [Brian Jones] “and using the 64 bit version of C4D (I forgot to ask)… To set Render Instances it’s in the Cloner’s Object tab, it makes the clones ‘instances’ instead of full copies and they hardly use any memory by comparison.”
    Well, currently I am using a 32 bit… I know that 32 bit only uses 3 gigs of the ram. So the problem is now:
    I have very limited internet each month. Is there a way to change your cinema 4D 32bit into a cinema 4D 64bit without downloading cinema 4D again?
  • Thunder Waffe
    August 18, 2012 at 11:46 am
    Sorry, I have found the 64bit version! Topic finished!
  • Gustavo Melo
    August 20, 2013 at 8:27 am
    thanks!
