Activity Forums Maxon Cinema 4D Cinema 4D R23 – Unable to write file
  • Cinema 4D R23 – Unable to write file
    Posted by Andrew Wagstaff on April 5, 2021 at 11:45 am
    This is a problem ive always had with cinema 4d and never figured out the cause or fix
    Ive animated a shot and render a viewport render but discover there’s something that needs changing so i make the change and tell it to render the shot again but it says unable to write file
    yet sometimes it overwrites the file with no issue I’ve made no changes to the render settings and now if i try to delete the video file while Cinema is open it says it cant because the file is open in cinema yet its a video file I’m trying to delete not the 3d file and I’ve never had that issue with the earlier versions
    Any help would be great
    George Charoupas replied 3 years ago 5 Members · 5 Replies
  • Justin Thomson
    April 5, 2021 at 2:43 pm
    It seems like an issue with what you are viewing the render with. How do you view the animation after? Are you opening the video ( or sequence) in c4d to view it?
    Sometimes you cannot re-write a file if it’s open, sometimes even if the preview is open in explorer/finder.
  • Andrew Wagstaff
    April 6, 2021 at 8:27 am
    I closed the folder the video is in and ti worked which is odd as I’ve never had that issue before, thanks for the suggestion
  • Brandon Robinson
    December 13, 2021 at 12:45 pm
    This happened to me, and it was because dropbox was syncing, the file must lock itself while syncing
  • Dean Mellis
    July 26, 2023 at 12:28 pm
    I had the same issue. Restarting C4D, restarting the computer, deleting previously rendered files, closing all other programs and setting an absolute output file path didn’t help.
    I was able to solve my issue by recreating my render setting. The only difference in the new setting was disabling Alpha for an mp4.
  • George Charoupas
    July 26, 2023 at 12:48 pm
    I had once a problem like this, but it turned out that was a problem with the folder permission. I had to reformat my system to fix it. What I did to solve my issue back then was to save all my Cinema 4D renders to C: directly. I never got an issue till the format.
    Also when you get your error try following this
    https://superuser.com/questions/117902/find-out-which-process-is-locking-a-file-or-folder-in-windows
    to see if there is a program that uses your file.
