Activity Forums Maxon Cinema 4D Cinema 4D problem
  • Cinema 4D problem
    Posted by Ramon Van sprundel on July 27, 2015 at 5:05 pm
    I’ve been having a quite interesting issue.
    So i create a camera, and then i set 4 keyframes:
    1. 0F, Rotate B 360°
    2. 40F, Rotate B 240°
    3. 60F, Rotate B 0°
    4. 300F, Rotate B 0°
    Now normally it would still go up and down a bit between the 3rd and 4th keyframe. but now it does nothing.
    Ramon Van sprundel replied 11 years, 1 month ago 2 Members · 3 Replies
  • Cassius Marques
    July 28, 2015 at 5:53 pm
    Seems to be a matter of how are you interpolating your keyframes…A linear mode would give you that behaviour. A bezier mode should give you the bounciness. A bezier clamped would give you the easiness without the overshoot.
    Open up a timeline for that track and check for those things to get your desired behaviour.
  • Ramon Van sprundel
    July 29, 2015 at 8:49 am
    I’m not sure where that setting is, when i click on the keyframe i can change the mode to linear, but nothing changed.
    July 29, 2015 at 9:00 am
    I found it on this forum
    https://forums.creativecow.net/thread/19/864105
    Apperantly the clamp mode is a really interesting one for camera movement.
