Activity Forums Maxon Cinema 4D Cinema 4D & Octane Only rendering one frame
  • Cinema 4D & Octane Only rendering one frame
    Posted by Christian Vilderman on September 7, 2015 at 4:56 pm
    Hi
    I am rendering 320 frames. EXR sequence.
    When I start rendering its just rendering the same frame over and over again.
    I have 3 baked soft body sims.
    FPS is fine.
    Any ideas?
    thanks
    Christian Vilderman replied 11 years ago 1 Member · 1 Reply
  • Christian Vilderman
    September 7, 2015 at 5:03 pm
    Basically you go to octane render settings and set method to send all scene data.
    Because I was using bake sims etc it was ignoring them sims as it was set to resend only updated objects.
    Small Victory
