Activity Forums Maxon Cinema 4D Cinema 4D Multi pass render issue.
  • Cinema 4D Multi pass render issue.
    Posted by Niks Wane on July 19, 2019 at 12:04 am
    Hi guys, I am new to cinema 4d. Till now I have been using it for still single image render. But now I am working with a project that requires multi pass process.
    But I am facing strange issue while rendering multi pass images.
    Since then I tried different kinds of projects, still & animated. Every time the same thing is happening.
    I have tried everything on the web but issue is still there.
    Here is the link of Test c4d scene file & screenshots.
    https://www101.zippyshare.com/v/AFDvoPF9/file.html
    Niks
    Emir Bojorquez replied 7 years, 1 month ago 2 Members · 1 Reply
  • Emir Bojorquez
    July 19, 2019 at 3:13 am
    Not sure to understand the main issue, but if you talking about the way it looks in multipass and the beauty pass (main one)
    You will spend hours trying to match your passes to the main one.
    A few recomendations are:
    -Render using Linear color Space.
    -Use 16 Bits/channel or 32
    – You are using Globall Illumination, add that to your Multipass too.
    – Increase your anti aliasing to 2×2 4×4 or better, or try to render with the Physical render.
    -tweak your settings with your compositor (after effects or Photoshop), like colors, blur, curves and so.
    Hope that helps.
    Good Luck
    Imagination is the best tool…
