Activity Forums Maxon Cinema 4D Cinema 4D Mirror Selection
  • Cinema 4D Mirror Selection
    Posted by Drew Smith on August 24, 2014 at 4:14 pm
    Hi there. I’d been modeling in Maya and there was an option to mirror a selection. Basically set the plane down the center of a symmetrical modeland whenever you make a selection or soft selection the software selects the corresponding points on the other side of the model. It was great because was just working on one model- not 2 halves of a model that would need to be stuck back together and have holes patched around the seam later.
    Is there any similar function in Cinema 4D? The only way I can find is to use the symmetry object and that makes it pretty time consuming to use soft selections because I end up with holes in the middle of the completed model at the end that I have to go through and fix.
    Cactus Dan replied 12 years ago 2 Members · 1 Reply
