cinema 4d (lite) camera animation problem
I’m working on a project in C4D lite for Adobe After Effects and I’ve attached the camera position to a predefined spline for my motion path. I’ve encountered various problems where during animation the camera will bounce around where there is supposed to be a smooth incremental transition.
For example, I have a set of keyframes in my animation panel which should animate the camera position from 46% to 50% to 51% and so on.
Instead, between 50% and 51%, this happens:
50%…50.1…50.2…50.3…50.4…50.5…50.4…50.3…50.4…50.5…50.6…50.7…50.8…50.9…51%So just in between to keyframed positions of 50% and 51%, the camera will bounce back and forth when there are no keyframes.
