Activity › Forums › Maxon Cinema 4D › Cinema 4D Importing Vector Logo …. ?
Posted by Kristian Aarli on August 2, 2011 at 8:50 pmHi.
I was going to import the vector logo AlJazeera and make it 3D…
But when I:
1: Clicked “File”
2: Clicked “Open…”
3: Choosed the vector logo and opened it in Cinema..
It just came up a window like this: cinematilcreativecow.pngSo pleeeeeeas help me!!! 😀
Kristian
Scott Warren replied 12 years, 6 months ago 4 Members · 18 Replies -
Tim Shetz
August 2, 2011 at 11:22 pm -
Kristian Aarli
August 3, 2011 at 7:47 amSorry. That doesn`t work either. I can`t get it 🙁
I`ve also tried to drop it in Cinema but the picture viewer (render window) Just pops up!…Kristian
Brian Jones
August 3, 2011 at 3:57 pmthen it’s not a vector logo, it’s just an image. Ideally you’d want an Illustrator 8 file
Kristian Aarli
August 3, 2011 at 4:17 pmI have done made it that to. And tried it 🙂 But the thing that happens then is that the project name changes. But nothing appears on the work area…
Brian Jones
August 3, 2011 at 4:39 pmto avoid the project name changing do what Tim said, use File/Merge instead of using File/Open, but either way if nothing shows when you load it in that might mean the file is corrupt (or not right somehow) or possibly it’s coming in at a very small scale and it’s too small to see. Can you post the vector file?
Kristian Aarli
August 3, 2011 at 6:16 pmHi.
I dont think the file is corrupt because I`ve tried to import other logos and images to. But those have the same result!
Check this images(this is a snapshot after I imported the Illustrator 8 file): creativecowquestion.pngPlease. Hope you have the right answer! 😀
Kristian
Tim Shetz
August 3, 2011 at 6:28 pmIt might be easier to help figure out the problem if you could post the file as Brian mentioned. That way we can try to import it or at least determine if there is a problem with the file.
If you have an illustrator 8 file and it’s not corrupt, you should get something when you do a merge…or even an open.
Just out of curiosity, how did you manage to go from a .gif to an illustrator 8 file? If you just placed the .gif in Illustrator and then saved it as an illustrator 8 file, it is still not a vector graphic. You would either need to convert it (via livetrace, redrawing it yourself, of finding an actual vector version) and THEN save it as illustrator 8.
__________
Tim Shetz
c4dtraining.com -
Brian Jones
August 3, 2011 at 6:33 pmif it will only load into the Picture Viewer or not at all it is not an Illustrator 8 file. It may be an Illustrator file but it was not saved out to the older Illustrator 8 format.
