Activity › Forums › Maxon Cinema 4D › Cinema 4d Hair behaves differently in Picture Viewer
  • Kouraib Abdmalek
    July 29, 2024 at 8:22 am
    Hi Eugene,
    When we rendering dynamics on the editor, it will ignore the previous frames to make the rendering faster, so you can’t know if everything is okay until you use the picture viewer that it calculate the dynamics from the first frame to the frame you want to render, so the rendering will look different if there is any problem, however, maybe everything is fine in your scene, you just need to make sure that the hair effect is there in the render setting, if it is not, you have to add it manually by going to Effect, if the problem persists, copy only the main object without the environment and paste it in a new file and save it, then close the program and reopen the new file and check the rendering, if the problem is solved, then add the environment again, and it is preferable to use new elements for the environment and not the elements that were in the previous file. Try this and let me know how the result was with you.
  • Eugene Tkhorzhevsky
    July 29, 2024 at 7:00 pm
    Dear Kouraib, thank you for your touch
    I find, that in my case, the problem is in Connect Object that use link to reference object, and them Correction Deformer apply to this Connect Object. I solve this problem partly by Make Object Editable function for Connect Object, and now all renders are predictable
  • Kouraib Abdmalek
    July 30, 2024 at 8:50 am
    You’re welcome, Eugene! I’m glad you’ve solved the problem, even partially. It may require looking at the file, but I think that baking the hair to Polygon might solve the problem since the situation has improved after making the Connect editable. I’ve put a link below showing the best way to do that.
    I hope this will be helpful to you.
    https://www.youtube.com/watch?v=Yn8X4ef_YM8
