Activity › Forums › Maxon Cinema 4D › Cinema 4d, Grass texture moves/ shadows don’t appear
  • Cinema 4d, Grass texture moves/ shadows don’t appear
    Posted by Zii Sparisia on July 21, 2019 at 9:14 pm
    Hello,
    I’m working on a project with landscapes which have grass texture, and I have 2 situations/problems:
    1. If I use hair render for the grass, then the shadows will not appear on the grass (tree shadows), and I do not understand why is that happening, can anyone help?
    2. If I just use an image (to get shadows), and I have my camera moving from a low side angle, then it appears as if the grass is moving (like sinking sands). I have UV mapping, but it’s not working. And if I try something like flat mapping, then it looks streaky and just weird.
    If you could help with either problems I would highly highly appreciate it. This is the last bit I have to fix to finish a project I’ve been working on for a few months now. HELP PLEASE and THANK YOU
    Jim Scott replied 7 years, 2 months ago 2 Members · 1 Reply
  • Jim Scott
    July 22, 2019 at 4:46 pm
    Perhaps you could upload your project file (or a simplified version showing the shadow issue if your project is large), because I don’t see the same issue on my system. Shadows seem to work fine on hair. I’m using R19 and R20.
