Activity › Forums › Maxon Cinema 4D › Cinema 4D File Crash recovery on a mac without autosave
  • Cinema 4D File Crash recovery on a mac without autosave
    Posted by Joao Monteiro on February 5, 2015 at 11:41 pm
    Hi all,
    This time I don’t have any query or problem.
    I would like to share with you my findings.
    If you were working on a cinema 4d file for hours and you didn’t save it, you can actually recover it.
    After a few hours trying to recover my files I found that if you go to:
    /Users/”YOURUSERNAME”/Library/Preferences/MAXON/CINEMA 4D R15_8C725DAB/_bugreports
    your recovery files will be there.
    In my case I wasn’t able to access that folder as it was invisible but if you do a Shift + CMD + G in finder you can go to that specific folder.
    If this folder doesn’t work for you, go to Edit – Preferences in Cinema 4D, go to the Memory tab and copy your Cache Path Folder replacing “/prefs’ for “/_bugreports”.
    Hope this works out for you as I believe there is no frustration as losing hours of work.
    From now on also set up auto-save as I just did.
    Cheers
    Joao Monteiro
    https://www.joaomonteiro.tv
    Brie Clayton replied 3 years, 2 months ago 8 Members · 7 Replies
  • 7 Replies
  • Ivan Wong
    October 26, 2015 at 6:59 am
    I DON’T KNOW WHO YOU ARE, WHERE YOU ARE, BUT THANK YOU KIND SOUL!!!!!
  • Peter Van der zee
    October 28, 2015 at 10:28 pm
    I know. Should have activated auto-save… but I didn’t
    I found the -bugreports folder but there’s only a txt file there and a .zip with the same text file.
    Am I missing something? How can I recover 4 or 5 hours of work from a txt file?
    http://www.zeemotion.com
  • Chip Webster
    January 10, 2016 at 6:32 pm
    Peter,
    Did you ever figure out why the file wasn’t generated or how to recover with only the text file?
  • David Cabestany
    March 31, 2016 at 8:54 pm
    Thank you thank you thank you!!!
  • Ekpeti Chuks
    April 7, 2016 at 7:50 am
    Thanks a lot for the info, I had similar issues although not a mac system. I was able to find the recovered files as u stated above, but the problem still persist as my c4d work keeps crashing over and over again when working on a project and it gets really annoying. I was advised to update my graphic card driver in my system and that miraculously solved the problem. I hope someone else finds this useful too.
  • Chad Ridgeway
    June 29, 2023 at 9:46 am
    Joao, OBRIGADÃO CARA SALVOU A MINHA VIDA OBRIGADO DE MAIS!!!
  • Brie Clayton
    June 29, 2023 at 1:59 pm
    Thank you, Joao, for this handy solve, and for saving Chad’s life!
